Can I use an upstream o2 sensor in downstream hole position?
Old Nov 11, 2015
WaryDriver's Avatar
WaryDriver is an unknown quantity at this point
1998 civic dx d16y7 with factory exhaust manifold and cat. I just need something to cover the downstream o2 sensor hole for a week. I have a spare upstream o2 sensor. Is it the same dimensions threadwise as the downstream? Same number of threads and same thread pitch?
I was going to leave it unplugged for my road trips next few days. Just want to know if mechanically it's not going to be different dimensions as upstream o2 sensor.
Cannot remove old downstream o2 sensor from old cat. It's like welded seized tried soaking in Pb blaster hammering heating
Old Nov 11, 2015
Re: Can I use an upstream o2 sensor in downstream hole position?
Yes.
All these are the same as an old 18mm spark plug thread.
Old Nov 11, 2015
WaryDriver's Avatar
Ok. Also the new aftermarket exhaust manifold's cat's bolt hole isn't threaded so can't transfer this stability? bracket from old cat to new cat. What is the brackets purpose that attaches cat to engine mount, stability of the down pipes? Do I need it? I'm thinking the stability will prevent stress from vibration and motion therefore prevents cracks. Name:  B05lEA1.jpg
Old Nov 11, 2015
You're right, the bracket needs to be in place.... I'd think the weight of the converter hanging off of a constantly vibrating engine, along with the rest of the exhaust movements, can eventually cause it to crack and break if that extra support bracket is missing from the bottom.
Run a tap through the hole and cut new threads in it, or maybe find a bolt size that will slip through the hole and use nut/bolt/washers to secure it.
HTH
