1998 civic lx
Old Oct 9, 2015
Swood's Avatar
Swood is an unknown quantity at this point
1998 civic lx
I have a 1998 civic lx and I am having trouble bubbles in my radiator over flow. The pressure has gotten so high that it has blown the radiator. The pressure gets high enough to push out the coolant and then overheat. I have replaced the head gasket 2 thinking it was a blown head gasket. I am looking for a little help do I have a cracked block? would that cause this to happen? Could it be the valve stem seal needing to be replaced? basically at a loss, love this car it has 200,000 left in it for sure.
Old Oct 9, 2015
Poopies's Avatar
Super Moderator
Re: 1998 civic lx
When you replaced your gasket, did you do it yourself or did you go to a mechanic? If it was the latter and they were reputable, they should have checked it for cracks and warping before completing the job. You could do a combustion leak test (rent a kit at a parts store) to eliminate or confirm an exhaust leak.
Old Oct 15, 2015
Wankenstein's Avatar
Re: 1998 civic lx
Possibilities:
1) Your radiator may be blocked up.
2) Water pump is failing but not completely failed enough to leak coolant.
3) Radiator fan not working properly
Jun 2, 2015 11:54 AM
MamaBear2015
May 27, 2015 12:04 PM
WaryDriver
May 27, 2015 05:54 AM
Fantaztik5
May 25, 2015 05:58 PM
MamaBear2015
May 18, 2015 07:37 PM
