Manual window regulator
Old Jun 28, 2015
old97civic's Avatar
old97civic is an unknown quantity at this point
I've decided I will finally do something about the window regulator on the driver's side. For years it's always been a PITA to roll down the driver's side window. Basically, you can't just crank continuously. You turn the handle a bit, then back it off, then advance some more, back it off, etc. If you try to just crank non-stop you will break the handle, which I did do once several years ago. Got a replacement from a wrecking yard. So now if anyone pays enough attention, they would notice the handles aren't the same colour.
I've seen the videos and it seems the regulator is straightforward to replace. BUT, I thought I would try to have a look at it before ordering anything. Is it worth just spraying some silicone spray down the vertical channels? Looking at the pic of the regulator it looks like the linkages of the regulator slide along a track at the bottom of the window (scissor lift style) and I suspect that would need lubing as well.
Mine is a coupe, I have noticed there are distinct parts for coupe vs sedan. Probably because door and glass are longer than on sedan.
Old Jun 28, 2015
Re: Manual window regulator
Absolutely!
Glass dragging in the rubber channel seals causes problems.
Green02civic
Jul 27, 2015 10:48 PM
jzhartman
22
Jul 23, 2015 10:42 PM
breanna_17
Jul 21, 2015 04:01 PM
estes53
Jul 20, 2015 10:43 PM
ballmich
Jul 9, 2015 11:59 AM
