2000 ex
Old Jun 10, 2015
tattedlariat's Avatar
tattedlariat is an unknown quantity at this point
2000 ex
From what I've read, this comes with a d16y8 engine. Mine has a d16y7 motor, according to the code.
I'm also throwing a bad ECU code... How do i fix this?
Old Jun 10, 2015
Re: 2000 ex
What code is this?
Old Jun 11, 2015
Re: 2000 ex
**** i can't remember. But its an electrical load distributer Voltage too high. Possible cause bad ECU.
But i'm not sure if its caused by a bad computer, wrong computer, wrong wiring harness, or what.
I'm half tempted to just throw a new motor in there and start all over.
Old Jun 11, 2015
Re: 2000 ex
P1298 is ELD (electrical load detector) voltage high. Did you try the ELD first?
/Occams razor
Old Jun 12, 2015
Re: 2000 ex
I haven't been able to find that part..
BUT.
Is the ignition coil between a d16y7 and a d16y8 the same?
Old Jun 12, 2015
Re: 2000 ex
My parts catalog does not work that way.
USA catalog M.Y. 2000 Civic, all except HX use the same part number ignition coil.
Crazygrlinak
Oct 8, 2015 05:06 PM
Le Ormz
Sep 30, 2015 09:24 AM
Hutch1051
Sep 29, 2015 09:20 AM
tropicola
Sep 25, 2015 07:02 PM
