Coil Springs.. my weight.. help..
Old Apr 27, 2015
oneheadlight's Avatar
oneheadlight is an unknown quantity at this point
Question Coil Springs.. my weight.. help..
I'm replacing the suspension in my 96 Civic coupe, manual trans. I've settled on the shocks, but for the springs there are two OEM replacements for the front one for automatics and one for manual models. The rears are the same between auto/manual. The spec difference is 957lbs per spring in the front for manual models, and 1038 load lbs for the automatic.
Now here's my question, I am a tall guy and weigh 300lbs, yeah I know I'm big, but with that weight I've had to have alignments with me in the car because I cause the stock suspension to sway to the left. They do the alignment with me in the car so I can drive straight without the steering wheel to the right.
I was doing some calculations for the 96 coupe and wondering if I should just use the automatic model springs on my manual trans civic because of my weight. That way I would have springs that would support me better.
Is this correct thinking? I did calculations based on the weight of the civic (2313lbs), distribution of weight (62%), then dividing that by two to get the individual corner weights. With that I then subtract what the replacement spring can support plus my weight. And all the calculations show with me in the car I'm beyond what the individual spring could support in the front! With the automatic model spring I'm fine.
So let me know if I am correct in my thinking, thanks!!
Old Apr 29, 2015
Re: Coil Springs.. my weight.. help..
update.. all I want to know is if it's safe to use the automatic model front coil springs on the manual transmission model?? I was going to use them because of the extra weight they could handle.. If anyone could help with this, I would appreciate the help!!
Old Apr 29, 2015
GolNat's Avatar
Prelude Owner
Yes it is safe. Just may not ride as well, but it probably won't be noticeable.
Old Apr 29, 2015
thanks for the reply! I really appreciate it. I was thinking it might be a little stiffer riding, but at least it would support my weight (290lbs, and 6'6 tall).. I kept having to have wheel alignments done with me in the car, now I know why, the springs were drooping/leaning to one side. Cool, be good that I can get this solved finally.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
h4ldol
Apr 24, 2017 08:16 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
