98 civic heavy vibration at idle
Old 04-11-2015
streetglower123's Avatar
streetglower123 is an unknown quantity at this point
my 98 civic with 175k miles has an extreme heavy vibration at idle. in drive with the ac on, its worse and vibrates through the car. bought a set of new, aftermarket engine mounts from ebay and installed them and it made no difference what so ever. is there anything common with these cars.
Old 04-12-2015
Prelude Owner
GolNat's Avatar
Re: 98 civic heavy vibration at idle
Did the mounts look worn/torn when you removed them? Cheap mounts can be just as bad as old worn ones.
Old 04-12-2015
the 2 front outer mounts (right trans mount and left engine mount) were completely broken). the other 3 top left engine mount by timing cover, back engine mount and top trans mount weren't so bad. but it is like there is another issue. or yes they are cheap mounts. but has anyone else bought cheap ebay mounts and had the same issue only to buy Honda mounts and fix the issue.
Old 04-12-2015
http://www.ebay.com/itm/251545451016?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
these are the ones I purchased. I will purchase oem ones and spend the money if I know that is the issue but not sure.
Old 04-12-2015
have googled this issue and have come up with a few scenerios. first is the mounts need time to be broken in and the vibration may go away. highly doubt this but second scenario is the mounts need to be tightened in a sequence. has anyone done this?
Old 04-12-2015
Every one who doesn't like the vibration!
Seriously, factory mounts are going to be the softest.
IF mounts were the original problem. Many other issues can cause a complaint like yours.
Called "neutralizing".
Read this http://honda-tech.com/honda-civic-2006-current-79/engine-vibration-stops-2447527/#post36669793
mikemc422
08-09-2018 05:41 PM
Pr0n1s
04-30-2015 03:08 PM
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
Civicchicky87
Idle Issues
04-22-2015 07:16 PM
vtechcivic
04-21-2015 06:58 PM
Quick Reply: 98 civic heavy vibration at idle
