99 civic VP idle issues
The car starts and idles fine on hot or cold startups. After the engine is warm and I'm in stop and go traffic, I come off the gas the idle goes real low and the engine basically stalls. if it doesn't stall after about 5 seconds the idle come up and corrects itself. I cleaned The Throttle body and the IACV, it didn't look too bad. put it back together and now its worse. when the car is warm and I come to a stop she stalls. I start it right back up and she idles perfect. also did an idle learn after putting throttle body back together. I also never get check engine light.
I want to replace the whole throttle body.
Does anyone think replacing the throttle body is the answer or am I wasting my time?
Can there be other issues causing this problem?
Re: 99 civic VP idle issues
Your 02 sensors (particularly the one before your catalytic converter) are how your vehicle's computer detects how well the fuel is burning by monitoring your exhaust gases. It then adjusts the amount of fuel that goes into the cylinders. If your sensor has been fouled (which is NOT uncommon), it can mess up the readings and your mixture can be burning too lean.
Bottom line: Check it. If it's old, consider replacing it with the correct part.
It's the original O2 sensors. I am the single owner. I'm not getting a check engine light or any codes. Can anyone tell me the normal readings on the O2 sensors when I connect the scan tool?
When I tested the resistance (from the electrical connector) it showed the sensor was bad as well. But I never got a check engine light!!
If the sensors are 16 years old, it's probably time to replace them. This will do nothing but help, I promise... even if it doesn't fully solve the problem. It's not difficult.
There 50 bucks a pop and there are 2 of them. I've been investing a lot of money into this car thinking its finally going to be a reliable car. Anyway enough about me. I played with the idle air screw on the top of the throttle body. Turned it a 1/4 turn counterclockwise and it seemed to clear up. Drove back and forth to work, no issues. Did I really make things better or worse?
I agree. Anything that makes your car run better IS better! You should still consider changing the upstream (pre-catalytic converter) sensor at some point... your fuel efficiency can only benefit from it!
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
