HELP! changing a/c belt b16 ek/ej
Hi Guys,
I'm new in this forum and I need some help/advice from you guys.
I'm having trouble changing the a/c belt in my ek/ej sedan.
I recently transplanted a b16a japan engine and it seems that the a/c compressor belt is wrapped around the engine support bracket which also houses the compressor itself. I was wondering how could I replace the belt without taking apart the whole bracket.
thanks guys in advanced
Re: HELP! changing a/c belt b16 ek/ej
Raise car on jack and safety stands
Might remove drivers front wheel for room
Remove 2 bolts (14mm socket) holding the bracket up in the drivers wheelwell.
Pull down on bracket and slip belt off.
Might need to lower engine by loosening the 2 vertical fasteners for the upper mount.
WaryDriver
May 27, 2015 05:54 AM
Paul Harsze
May 20, 2015 11:37 AM
