ticking noise in engine
Old Mar 7, 2015
siguy2's Avatar
siguy2 is an unknown quantity at this point
I have a 2000 honda civic si, b16. When the car is idling it's making a ticking noise but when I push in the clutch it stops, it does the same thing in every gear as well when I coast. Don't really know that much about cars and I'm not sure if it has anything to do with my valves or my clutch, please help!
Old Mar 7, 2015
Re: ticking noise in engine
Transmission noise.
Usual problem is input shaft bearings but really could be anything inside it.
Double check with an expert that can hear your noise though.
When the bearings get really really bad, the trans can howl like a dog poopin broken glass.
Old Mar 7, 2015
siguy2's Avatar
Thanks for the help! How long do you think I can run on it before getting it fixed?
Old Mar 7, 2015
I can't hear the noise, so I can't even guess an answer the question.
You should probably seek that answer from an expert local to you that can hear and evaluate the noise firsthand.
Is the trans fluid full?
That's probably the first thing to check. If it's low, leaking, or empty, it won't last long. Refill and fix the leaks.
HTH
bokogabe
May 21, 2015 09:27 PM
Supramk3
May 11, 2015 07:55 PM
CurryBomb
May 8, 2015 10:16 AM
BootyDo
May 7, 2015 04:46 PM
silvervtec01
Dec 9, 2001 08:50 PM
