Help! Speedometer issues!!!
Old Jan 12, 2015
mikemc422's Avatar
mikemc422 is an unknown quantity at this point
So... I have a 2000 Civic Ex coupe that has an issue with the speedometer, I just bought the car, and the girl I bought it from said it was working a month ago (no proof it was). The car was originally an automatic transmission car (I believe, at least all interior components except the shifter and clutch suggest it was an automatic, including the dash) and is now a 5 speed. I also believe the engine is aftermarket, it is the D16Y8 (love the engine, its in my other civic too) and the oxygen sensor is missing, but there is no check engine light on. I have never worked on imports, but could fix anything on an old ford, so for you mechanics out there you know I'm in a whole different world. I don't know why, but the speedometer is not working at all no matter how fast or slow I'm driving. I don't know what to look for, but if someone can tell me I'm sure I can figure it out.
Old Jan 12, 2015
Re: Help! Speedometer issues!!!
Does it have a check engine light that actually works?
Is the light actually connected to the computer at all, or is it jumpered to the oil pressure/alternator light?
Plug in a real scanner (or Scangauge, etc.) that can give live operating data on the fly.
First check for any fault codes and proceed with troubleshooting accordingly.
(You'll need to know if it was converted to OBD1 also, a typical code reader won't talk to OBD1 system.)
Does scanner display accurate VSS data while driving?
Does scanner display any O2 sensor data?
Old Jan 12, 2015
mikemc422's Avatar
I'll have the computer checked, but I know the check engine light works because it came on when I stalled the car the first time I drove it (very low idle, didn't give it enough gas)
Old Jan 13, 2015
It's easy for someone to rewire it to make the light come on at about the right time.....
Now figure out if it's really connected to the computer. I have a strong suspicion it is not.
Old Jan 16, 2015
mikemc422's Avatar
so, I texted the previous owner, and the transmission was originally automatic (now 5 speed), and when she did the transmission conversion, she swapped the computer, but she doesn't know what type of computer she put in.
youngm
Jun 4, 2015 10:19 PM
dragonsblood
Apr 27, 2015 12:28 PM
APS
Apr 5, 2002 08:48 AM
Player1
Mar 21, 2002 02:52 AM
ChRiStheSTD
Mar 8, 2002 05:09 PM
