98 civic Hx automatic wont rev
Old Jan 11, 2015
  #31
Re: 98 civic Hx automatic wont rev
I thought your complaint was that the engine can't rev all the way to redline and has little or no power?
I was guessing that sounded like an airflow restriction, such as a clogged catalytic converter or maybe a clogged air breather inlet.
(I've found breathers LOADED with dog food before, due to rodent activity).
Old Jan 14, 2015
  #32
Ts civic's Avatar
<<learning for my Daughters civic,,lol
Ts civic is an unknown quantity at this point
Originally Posted by Ts civic
Ok ok This is the only thing that makes changes I poured sea foam in the vacuum port and It revs up only when I pour it in,,when Im done it quits revving
Is this site for real,,,? or am I looking in the wrong place for info
Old Jan 14, 2015
  #33
mikey1's Avatar
Old Jan 15, 2015
  #34
Ts civic's Avatar
I'm not tryin to be a smartass but it is hard to explain on here . Anyways it runs fine until 4000 rpm it cuts out and if I back off the throttle a lil it will pick back up but never goes over 4000 rpm,,,,the only way is pour seafoam in the intake at the same time I rev it up but when I quit pouring it goes back to under 4000rpm
Old Jan 15, 2015
  #35
I think I understand now....
If the car is not moving, shifter is in park or neutral, then what you describe is correct. The computer limits no-load engine RPM to help avoid engine damage.
You have to have the car in gear and be driving (computer must detect a valid VSS input) in order to get the engine to rev higher than 4000.
Old Jan 16, 2015
  #36
Ts civic's Avatar
OK I have a question ,,the fuel line goes into the rail right it has 2 tabs to line it up right,,OK how many crush washers are supposed to be on there ,? I have 4 aluminum and 2 copper is that right ???? Just curious ,,,Thanks
Old Jan 16, 2015
  #37
One on each side of the line fitting....
A design could use soft copper or aluminum crush washer or maybe even a rubber gasket. Depends on what needs to be sealed and what's flowing in the system. On a fuel system you can mix aluminum and copper, no problem as far as I know. They just have to seal up and not leak fuel under pressure.
A sealing washer needs to be placed between each solid item in the stack.
Like
Bolt
Washer
Round fitting
Washer
Fuel rail
Or if you had a double line stack it would be
Bolt
Washer
Round fitting
Washer
Round fitting
Washer
Fuel rail
alexkharden
Apr 23, 2015 07:13 PM
vino
Bolt-on Engine Performance
Nov 10, 2001 04:13 PM
locozoko
Nov 8, 2001 06:33 PM
vexxed82
Nov 6, 2001 08:00 PM
Guy01
Nov 6, 2001 03:25 PM
