97 civic cx sputter/bogwhen accel/const speed
Old Oct 27, 2014
bluesmoke's Avatar
bluesmoke is an unknown quantity at this point
My 97 civic when accelererating and if driving at a constant speed it will just bog out then jerk n go again repeating that having to constatnly switch gears as its a 5 speed. just redid the plugs and fuel filter has oil if anyone has any idea what it could be please help me out!!!!
Old Oct 29, 2014
civic98?'s Avatar
civic98? is an unknown quantity at this point
Re: 97 civic cx sputter/bogwhen accel/const speed
Can't say for sure but I had a simialar issue with my 98/. try unplugging the 02 sensor on the manifold and then drive it see if it runs any better. It will turn on your engine light just an fyi but it will go out after you plug it back in. If it runs better probably that sensor. Mine mainly did it when it warmed up. good luck
Old Nov 8, 2014
bluesmoke's Avatar
hey man thanks for the info any chance u could walk me through how to do the sensor? new to these civics haha enjoy the car a lot this problem is just annoying!
Old Nov 8, 2014
Just locate the primary O2 sensor, then find its wire connector, and unplug it.
Now test drive it like that to see if the problem is gone.
blows some blue smoke after idling for to long as well
How many miles are on this engine?
Old Nov 8, 2014
bluesmoke's Avatar
276,000 on engine. is that bad?
Old Nov 8, 2014
I guess it's certainly old enough to smoke.
Quitting smoking is tough, just ask any smoker.
Maybe try getting it on the patch?
Old Nov 9, 2014
CNTLOSE's Avatar
CNTLOSE is an unknown quantity at this point
Not bad, but worn. 300k miles is a lot even for a Honda. Make sure you keep an eye on the fluid levels.
If by chance you are running the original exhaust the catalytic converter may be shot. I had a Sunbird way back in the day and it did the same thing. Converter was clogged and broken down. Replaced and took care of the issue.
Old Nov 11, 2014
bluesmoke's Avatar
should i pull the whole sensor out or should i just unplug it?
Old Nov 11, 2014
Leave the sensor bolted in place. It's only a test at the moment.
Just unplug the wiring connector from the harness so the computer can't use its input.
Old Nov 20, 2014
old97civic's Avatar
old97civic is an unknown quantity at this point
I did this test too earlier in the fall as I have the same issue, but it's intermittent for me. It ran a bit rougher especially at idle with the O2 sensor disconnected but never saw the hesitation during that test. Then I didn't see hesitation for a whole month and now I just experienced it again once yesterday. Yes the check engine light will come on when you drive around with the O2 sensor disconnected. It didn't turn off on its own when I reconnected it (maybe I didn't drive long enough), but I pulled the BACKUP fuse and that cleared the light (this fuse is in the fuse compartment in engine bay next to battery).
Is this condition intermittent for you or all the time?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
dragonsblood
Apr 27, 2015 12:28 PM
GH04si
Apr 15, 2015 08:13 PM
dooner24
Apr 14, 2015 07:51 PM
LexBoy
Nov 5, 2001 08:00 PM
