transmission range sensor... plz help
Old Mar 22, 2014
chalisewaters's Avatar
chalisewaters is an unknown quantity at this point
Is the transmission range sensor in or out of a 97 Honda civic lx none v-tech.....
It looks Like this
Old Mar 22, 2014
Re: transmission range sensor... plz help
It looks Like this
That question(?) does not make sense to me, as written. What is it you are wanting to figure out?
In my world
Trans Range Sensor = Gearshift Position Switch.
Your picture is not what I consider to be the gear position switch.
I really can't even tell what the item in the picture is, I don't recognize it.
Old Mar 23, 2014
Unhappy Re: transmission range sensor... plz help
The picture is suppose to be a transmission range sensor for a 1997 Honda civic lx 1.6 engine none vtech. And my question was " when getting your transmission range sensor, are you more likely to take the transmission out To fix it or do you leave it in. The codes I got were p0705 showing a transmission range sensor 2 post. I'm having a hard time of anyone knowing what I'm talking about.
Old Mar 23, 2014
No wonder....I can see why.
I don't know what it is a picture of, but I know what it is not.
It's not a gear position switch for a Civic of that year with an automatic transmission.
Well, why didn't you say so?
The gear position switch is nowhere near the trans.
It is attached to the passengers side of the shifter assy., under the center console.
Should have 7 wires.
Part #2 in this pic
Link to catalog: http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry 2=1997&catcgry3=4DR+LX+%28A%2FC%29&catcgry4=KA4AT& catcgry5=SELECT+LEVER
What's a "2 post"?
There shouldn't be a P0705 at all in that car.
How about a P1705 code?
If it's a P1705
The computer had to see more than one of the gear position switch circuits turned on at once.
Drinks that have been spilled into the shifter area can cause the P1705 code.
If you are lucky you can simply remove the switch and clean it out.
Hot soapy water and a good drying might fix it.
HTH
Old Mar 25, 2014
Thumbs up Re: transmission range sensor... plz help
Sorry for the miscommunication I'm a single mom and don't really know much about cars so I try to do a little research when getting my car fix!!!! But thanks a million times..... This was very much helpful, now I can stop pulling my hair out.
Old Mar 25, 2014
Is that picture of a transmission range sensor? Just so that I am clear. And no, any other codes came up about the sensor or sensors. Again sorry for any misconfusions
Old Mar 25, 2014
Question Re: transmission range sensor... plz help
Is the proper name for it would be " speed sensor" because every time I search transmission range sensor for my module car it pops up "speed sensor.
Old Mar 25, 2014
Whatever item I pointed out in the picture is the gear position switch. Honda does not call it the same name you keep calling it.
No it is not a speed sensor.
If you want the correct part on (almost) the first try, you should use a Honda dealer.
I linked to the online dealer catalog at the bottom of that picture. They sell by mail order and at a significant discount. (Shipping is extra.)
The fix for the P1705 code could be completely free if removal and cleaning of the switch is successful.
SidCivic
44
Oct 12, 2017 03:39 PM
knknif
Aug 4, 2015 06:11 PM
Brandon Vlasak
Jul 25, 2015 07:25 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
jody501
Jul 10, 2015 11:01 AM
