99 Civic gli EK1 Clutch and Battery Fun
Old Feb 27, 2014
PoSSeSSeD's Avatar
PoSSeSSeD
PoSSeSSeD is an unknown quantity at this point
Cool 99 Civic gli EK1 Clutch and Battery Fun
I have always skimmed the honda forums for info for many a year, without a great deal to offer i refrained from adding more dribble to a good forum.
Firstly off my own back an key friends i came to a clutch kit decision.
i have got myself a ci clutch industries kit at a kick bouncy ***** price so im happy with that i believe they are above the line in standard ??
My car is struggling as i baby it not to far from home, i wonder the flywheel damage ? i was getting the XTD stage one kit with lightened flywheel but not working with a family to care for after research and chat with my older cousin who holds his trade and drag races i respected his opinion.
The big question, flywheel. Is it clutch gets done fly wheel machine is a must ? or does a few heatspots an no serious groves cracks an damage pass the ok to move along without removel transport and wait for resurfacing ?
I respect the your help more so from seniours or rep users. people i trust say a few heatspots meh all good, were doing it ourselves so the consideration to removal of the flywheel getting it done hopefully in a timely manner getting it back home to fit it ect. for a surface not to bad at all is it that important / o do understand the issues surrounding it and i have not seen the flywheel yet but if it seems to be short of great is it completly necessary ?
__________________________________________________ _____________
this battery part is short to the point, starting the car recharges the battery fine. if i try start it light on fuel and it doesnt turn over after a good 20 seconds, i need to hope im on some kind of slope to clutch it cos if it doesnt start it stops turning over and it click click clicks,
Note the car recently needed a bluey so 3 or 4 times rthe battery got charged sat there and emptied. Im assuming it is the battery i can hold only for example 15% charge at anytime. i must check fuses tomorrow and the indicator on the battery. but im almost sure its the battery getting charge then death multiple times during repairs to get the blueslip.
Could it be low on fluid ?/ can it be filled up with distilled or try the soda method on it >. if i had the battery money id do it, spent much on rubber n panels ect to pass blueslip, im now doing the clutch first time after 150k
if i could add 6 months to the amarco battery id like to.
i can rile out solanoid and starter motor an recharging. The battery is always indicating less than 1/4 life, even at drainage after a run hes fine.
ill also check the terminals clean and create better clamping.
during the repairs ( i nudge the butt of a 4wd, towbar into the air con cooler.
detatching instaslled there was a clip i found no home from, read some wwere about another ground to the thermos being the problem /
without voltage readings iv covered it all and rounded it to those points.
Can life be brought back to a car battery with distilled watter like my old man did way back when.
i much appreciate assistance to those willing to take the time out tio assist me.
Old Feb 27, 2014
Re: 99 Civic gli EK1 Clutch and Battery Fun
G'day
I personally have not heard of that brand.
Probably best to stick with stock replacement if it is a pretty stock engine. IMO
Must inspect upon disassembly, then evaluate and see if you wish to risk chatter and whatnot.
If it isn't scored by contact with rivets, or cracked from heat, I have had good luck just reusing the flywheel as-is without machining or replacement.
Inspect and evaluate when you get it apart.
A what?
If a car battery sits long in a discharged state, its life and capacity can be dramatically reduced.
What you describe kinda sounds like that's what happened, or it's sulfated.
If it is already sulfated, just get another one. A sulfated battery can discharge by itself rapidly, as quick as overnight.
Some snazzy battery testers can't tell if the battery is sulfated....
but I'd say to get it tested anyway.
If you can pry the caps off you can add distilled water if need be. May or may not help.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
