Civic won't start please help. Dash removed
Old Jan 20, 2014
Genyc07's Avatar
Genyc07 is an unknown quantity at this point
I am doing an interior swap. Today I disconnected my negative terminal. Then removed the center console and pulled the entire dash I disconnected the harness from every point. Then reconnected everything except the power mirrors, the sunroof, the right side airbag and the radio. None of the wiring clips gave me trouble coming out or going back in. I turned the key Once back together and the cars srs light was on as expected because It was removed. I crank the starter and got nothing. I rechecked all the connections disconnected negative plugged the dimmer and mirror reconnected negative on the batt and tried again and again it only cranked.
Everything seams to be connected I have not chased fuzes. I do not have an aftermarket alarm. What did I do how do I fix it.
When I say I pulled the dash, I mean the entire thing windshield back everything. Please help thanks.
2000 ex stick unmoddified
Old Jan 20, 2014
Re: Civic won't start please help. Dash removed
Oh Gadz. You need to go recheck everything you touched. there are a ton of places for errors to happen.
And it seems like no 2 people do a dashboard pull the same way.
Some disconnect far more than necessary, others don't unplug the last wires until they discover the dash won't come out without it. (WHOOOPS! Where did those wires come from???)
ECM all plugged in?
Main relay connected?
All connectors right?
Ground wires?
Blown fuses?
Does the check engine light come on?
You may just have to pick an item that doesn't work and track each wire to find what you might have left undone....
Old Jan 21, 2014
Genyc07's Avatar
Hooking it up to the computer tomorrow. But just asking the right side airbag disconnected and the radio out wouldn't cause it would it? The is no secret theft prevention right? I can't find any plugs that need to be connected. I feel so stupid right now. Ugh.
Old Jan 21, 2014
Old Jan 21, 2014
Genyc07's Avatar
No It wasn't on
Old Jan 21, 2014
If the check engine light does not come on when you turn the key on, then the ECM isn't powering up for some reason.... (assuming the rest of the idiot lights still do come on when you turn the key on)
All the ECM connectors plugged in all the way, none only halfway pushed in?
Old Jan 22, 2014
Genyc07's Avatar
Missed a plug that was hiding by the glovebox. Back in action thanks ez.
Old Jan 22, 2014
Koolz!
CarStuff
Dec 6, 2020 12:52 PM
vtec92
May 4, 2017 03:20 AM
Linda0818
Apr 23, 2015 11:30 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
