car leak, cant identify problem!!please help
Old Dec 18, 2013
alicia9274's Avatar
alicia9274 is an unknown quantity at this point
I have a 98 civic ex with an oil leak on firewall side of engine behind between the alternator and the engine block. The oil is showing on the oil pump I think from diagrams. But its so high on the fire wall side of the oil pump when parked I think it has to be coming from some where higher. I was thinking a cam shaft seal but there are a couple of bolts and stuff around there and it would sure be a lot easier if it was a smaller gasket or something. Anyone have a similar leak. What was the problem with yours. I am not sure exactly what is on that side of the engine above the oil pump but under the head gasket that could be leaking.
thanks for helping a noobie I did search first with no luck.
Old Dec 19, 2013
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: car leak, cant identify problem!!please help
Sounds like possibly your Vtec valve.
LionSpratt
Jan 29, 2017 11:07 PM
usajags84
May 10, 2015 08:11 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
MamaBear2015
26
Apr 16, 2015 11:08 PM
CIVIC9782
Nov 3, 2001 10:33 PM
