clutch issue? I think? help!
Old Dec 16, 2013
bradr27's Avatar
bradr27 is an unknown quantity at this point
Unhappy clutch issue? I think? help!
So its a 2000 and it is the original clutch however I thought it was fine.
Its -13 celsius here with a foot of snow. I went to start it yesterday ( after having problems getting the shifter into gear the day before) and I found when I pushed the clitch in it was sticking and it felt weird. When I tried to start the car it was lurching forward and bouncing like I was letting out the clutch while driving without giving it enough gas. After 4-5 tries it actually started but the shifter would hardly move at all let alone go into gear. This may be a dumb question but is the clutch hydraulic?does hydraulic fluid need to be topped off? Or is my clutch just screwdd. Please help!
Old Dec 16, 2013
bacascooby's Avatar
SOUTHERN SLEEPERS CAR CLUB WACO, TX
bacascooby is an unknown quantity at this point
Re: clutch issue? I think? help!
I would check the fluid sounds like it doesn't like the cold how does it act when the car is at temperature
Old Dec 16, 2013
GolNat's Avatar
Prelude Owner
Could be water in the fluid causing it do that or a failing clutch cylinder or slave cylinder. Fluid level should be filled to the mark. If the level keeps going down then you have a leak (most likely internal, either the master or slave).
Old Dec 16, 2013
Sounds sorta normal to me.
First winter with the car? Get used to it.
Old clutch fluid? replace with fresh DOT3
Wrong trans fluid?
duder
15
Jun 11, 2015 04:28 PM
The Big Dutch
Jun 9, 2015 07:49 PM
Black91civic
Jun 6, 2015 08:15 AM
jackshepardjr
May 24, 2015 09:53 PM
crowtoo
May 11, 2015 06:50 PM
