Oil in air filter
Old Aug 23, 2013
unicorncar's Avatar
unicorncar is an unknown quantity at this point
Oil in air filter
Honda Civic 99 Si.
I have an aftermarket K&N air filter.
What are the causes for engine oil on my air filter and in the tube it attaches to?
I fear I'm screwed.
Old Aug 23, 2013
Poopies's Avatar
Super Moderator
Re: Oil in air filter
So is there oil all over the inside or outside of your intake? Did you check the smaller PCV tube and the valve on the engine block it's connected to?
Old Aug 23, 2013
unicorncar's Avatar
The oil is on the inside of the air filter and exhaust tube that its connected to.
I took the air filter off to clean it and noticed.
No i have not checked the PCV tube or valve connected to it.
It didn't occur to me.
I just looked up what a PCV valve does.
What exactly am i checking for?
Why would this valve being broken cause oil in my air intake?
Old Aug 23, 2013
Poopies's Avatar
Super Moderator
Originally Posted by unicorncar
The oil is on the inside of the air filter and exhaust tube that its connected to...
The crank case is one of the key areas that are lubricated by engine oil. It's pretty unlikely that the oil would have come all the way up through the intake manifold and into your intake itself since the airflow would be going the other way. If oil is leaking into the valve then you may have a leak somewhere in the engine. That, or maybe there's too much oil in there or something. How much oil did you put in on your last oil change? When was it? How is your oil level looking now?
Whatever you do, make sure you clean the throttle body and intake out well. Can you take any pictures of the problem?
Ninetyatecivic
May 9, 2015 07:48 PM
carid
Apr 30, 2015 07:00 AM
joe
Dec 10, 2001 10:33 AM
