No crank no start..please help
Old Jun 24, 2013
andress1021's Avatar
andress1021 is an unknown quantity at this point
I got a no crank no start on my 99 ek 5 spd. I jumped the starter with a screwdriver so thats ruled out. Stayed running with no check engine.i aldo jumped clutch switch still no start. I dont know what else to do please help
Old Jun 24, 2013
Re: No crank no start..please help
Jump the other clutch switch?
Old Jun 24, 2013
Theres only one, theres a bolt where the other one is suppsed to go
Old Jun 24, 2013
OK then, about all that's left is a starter cut relay and a bunch of wiring. Twist the key to start and work the clutch pedal up and down slowly, can you hear the cut relay click on and off as the pedal switch engages and disengages? Time to get a meter or test light and a wiring diagram.
This has some diagrams in it, give it a read. http://www.justanswer.com/honda/431o...d-starter.html
Old Jun 25, 2013
Theres no pedal switch but the wires are jumped, according to the pocture i was looking at the wrong relay i will test it today, wiring diagram helps alot thanks
Old Jun 25, 2013
Thanx alot i got it running the wiring diagram helped out alot i found no power coming out of the ign switch going to the relay. Dealer wanted $160 went to the yard and got me a new switch for $30
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
68camerors
Sep 24, 2015 06:18 PM
Skunkone
Sep 24, 2015 04:38 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
