A/T shifting problems
Old Jun 10, 2013
megapossum's Avatar
megapossum is an unknown quantity at this point
Why would 2000 civic with a/t have difficulty shifting from 1st to 2nd, 2nd to 3rd etc. The rpms go up with out shifting, back off on gas and it will shift finally. Doesn't seem to be slipping, just not shifting all the time as it should. Is there a vacuum line or device connected to trans. that may be at fault? Any help will be greatly appreciated!
Old Jun 13, 2013
ram0042's Avatar
ram0042 is an unknown quantity at this point
Re: A/T shifting problems
Have you ever switched on your shift lock? And/or do you manually shift elsewhere from the D4 on the gears? It should be normal wear if you do shift yourself daily.
97-DX-Lover
Jun 14, 2015 06:07 PM
Blazz
Jun 4, 2015 01:04 AM
usajags84
May 30, 2015 06:49 PM
cruisers10
May 12, 2015 10:46 PM
Marcus2thextrem
May 10, 2015 03:08 PM
