Loses power, no check engine light
Old May 23, 2013
itsrname2's Avatar
itsrname2 is an unknown quantity at this point
I have a 1996 honda civic hatch back, 5 speed. Has new wires cap rotor plugs, just cleaned the air filter. Everything has been running great, The last week, about 30 min into driving, the car will start to lose power, almost like its going to shut off, I let go of the gas then its ok, then i push the gas again then its like its not getting gas, then it starts working again. It idles great. no other issues.
I am going to try to put some seafoam in it this weekend. and make sure the throttle body is cleaned out. and Check my grounds. Any other ideas? Also it has been hot, so been using the AC, when it happens I have turned off the AC to see if that is the issue but it still continues to do it even after it is turned off.
Old May 23, 2013
Levi likes si's Avatar
Levi likes si is an unknown quantity at this point
Re: Loses power, no check engine light
I would look at the cat. that's what it sounds like to me
Old May 23, 2013
ishjay's Avatar
ishjay is an unknown quantity at this point
if its not that, then check your alternator cause it helps charge the battery.
Old May 31, 2013
itsrname2's Avatar
The Cat is only a year old, magnaflow direct fit. Reason why I changed it before the manifold had the Crack in it so I upgraded to the magnaflow cat and header.
I noticed it only does it at part throttle, like it is starving for gas, im wondering if it is the throttle position sensor now, but it is so weird it only does it mid day when it is hotter out. in the morning I have no issues at all
Old May 31, 2013
hondas4lyfe's Avatar
kell
hondas4lyfe is an unknown quantity at this point
throwing any codes? after i put my exhaust on i guess one of my o2 sensors got messed up a bit. it wouldnt throw a code for days but i would be driving and all of a sudden id lose power with my foot on the throttle, release n itd be fine.
Old May 31, 2013
kell
and is ur actual electrical thats dying or ur fuel? car has no issues turning over?
Old May 31, 2013
itsrname2's Avatar
Yeah not issues turning over, and no codes, I wish there was a code. And no issues turning over and no electrical issues. its seems to be fuel, I can be driving steady at about 50 or 55 then the car starts to lose power, I push on the gas more and I can hear like the engine is boggin down, then I push the gas more then it picks up again and sounds better, is a manual so it also does this at lower speeds too. if Im driving anything over 3500 rpms then its fine, if im steady driving at about 2,000 to 3,000 it starts acting like its losing power.
Old May 31, 2013
kell
yea then might be ur throttle postion sensor. but id start small and work ur way up. if u have noticed an all around power loss id say itd b somthing as small as ur fuel filter. remove ur fuel filter and blow through it and see how much resistance there is. check ur spark plugs too.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
deus-ex
Apr 13, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
