97 Honda Civic EX - Won't Start After Transmission Replaced
Old Apr 3, 2013
charparkuf's Avatar
charparkuf is an unknown quantity at this point
I have a 97 Honda Civic EX with 163K miles. I recently had my transmission replaced which is when the ignition problem started to occur. The engine was running perfect when the car went in for the transmission. After getting it back there was a slight but noticeable misfire. This misfire got continually worse over a one month period, eventually leading to the car not staying on (also, toward the end, a loud banging sound coming from what I believe was unburnt fuel hitting the cats in the exhaust). I do not believe in coincidence so I am wondering what my mechanic might have done, intentionally or unintentionally to cause an ignition misfire when replacing the transmission.
Any advice is greatly appreciated, thank you.
Old Apr 3, 2013
charparkuf's Avatar
Re: 97 Honda Civic EX - Won't Start After Transmission Replaced
Also, replaced plugs, wires and rotor to no avail.
Old Apr 3, 2013
jimmycivic's Avatar
jimmycivic is an unknown quantity at this point
yea that's not right its a simple drop and replace from underneath he had to of touch something besides tranny do your timing belt water pump and tensioner and see if it goes away he might have advanced timing on the crank a tiny bit past the two arrows to make it seem like a misfire when i changed my very first timing belt on a civic that was the result in my inexperience with interference engines when i first started but first because thats a big job check your cap or rotor again it could just be loose make sure all the screws are in
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
