1998 Civic EX false tachometer readings
Old Feb 27, 2013
Cheapshot's Avatar
Cheapshot is an unknown quantity at this point
1998 Honda Civic EX
5 Speed
Problem: Tachometer reads about 3000 RPM at cold start and increases as I accelerate. Tach usually corrects itself to correct RPM reading but will often jump back up and read very unusually high RPMs as I drive under normal conditions.
Mileage: 233,990
Recent repairs: Distributor O-ring/seal replaced
This problem started after I had the distributor O-ring/seal replaced, not sure if the two are connected or not.
Any help with possible diagnosis for this would be appreciated
Old Feb 28, 2013
Re: 1998 Civic EX false tachometer readings
Wild guess: bad tach.
Old Sep 29, 2017
Hondaguyej8's Avatar
Hondaguyej8 has a spectacular aura aboutHondaguyej8 has a spectacular aura about
Got a 98 Civic y8 auto. Replaced the dizzy and now my tach reads about 1k high. Sometimes more, less, sometimes it works. I believe the yellow with blue stripe wire on your obd2 dizzy plug controls tach. Check for shorts, new eBay dizzy had loose internals from factory.
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
ashleymmackey
Apr 18, 2015 09:48 PM
McD
Apr 16, 2015 10:46 AM
Hrddrvs
Apr 11, 2015 11:22 PM
