Can't figure this P0505 out
Old Jan 28, 2013
Travie_Vtec's Avatar
Travie_Vtec is an unknown quantity at this point
Got a CEl the one night, P0505.
I thought I fixed it. Changed the IACV. Found a vacuum leak. Capped everything off. Got rid of a cracked vacuum tank that had no purpose. Relearned the ECU. Burped the coolant.
I got an Innova 3100 obd2 scanner. When I used it, it said I had 2 codes, both P0505. When I clear then, I got a yellow light on the obd2 reader for the emissions saying there's a problem. Once I start driving, the car seems fine. If I park and and turn it off and check the OBD2 reader, i still see a p0505... even with no CEL.
The other day I removed the vacuum tank for cruise control, and capped off the hose that goes to it. I checked my OBD2, no codes, and a green emissions light. I thought I was done... this i got to work and sat in the parking lot in Park, and then my idles gots up and I see that CEL. FML
I still get an idle that slowly goes from 1000 to 1500 and then after a minute of two, drops to 8-900, then gives me a CEL, and a constant ~1500 rpms.
I have searched and searched, asked the jerks on H-T (with very little help or replies).
Am I missing a vacuum hose? i know theres a hose that goes down through the intake mani, but I can't seem to find where it goes.
Car is a 1999 Honda Civic EX with a "D15Y8" and is automatic
Will adjusting the idle screw possibly fix this?
Old Feb 8, 2013
Re: Can't figure this P0505 out
No lie, the local honda dealer service manager said that if you put a CAI on a civic, you will get a CEL.
BS.
Old Feb 17, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Have you cleaned the throttle body out?
It may be a good idea to see if adjusting the idle screw will help.
JMKendrick
Sep 16, 2015 06:17 PM
Donahue
Sep 9, 2015 05:55 PM
MamaBear2015
Sep 7, 2015 06:00 PM
NROD315
Sep 4, 2015 09:22 PM
