steaming engine
Old Jan 26, 2013
discotu's Avatar
discotu is an unknown quantity at this point
steaming engine
Hi All, first time here...wish it started out on better terms Anyway, i have a 1996 Civic and I thought i blew the head gasket yesterday...Steaming engine and coolant was milky...though the engine oil on the dip stick didn't apear to be contaminated. I checked again this morning and isolated the steam to the area noted in the picture. Not sure where exactly but doesn't appear to be near the head gasket. ANy ideas?
thanks in advance!
Old Jan 26, 2013
Re: steaming engine
You have a whole lot of mess there, looks like years and years worth of oil leaks and grime. Clean it all spotless and start over.
If you can get it all spotless, then throw a bunch of powder all over (ordinary bath talc). Fresh leaks show amazingly well in white powder.
Whatever WAS smoking came from somewhere else. The powder can help you figure out the path it took. And help figure out what it was.
Was the radiator low?
Old Jan 31, 2013
s4boost's Avatar
s4boost should not be trusted
Re: steaming engine
^what he said. if your coolant is milky thats no good. drain your oil and see what it looks like. clean that up with some brake parts cleaner and then check it after 20 miles
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
Cross
Jan 6, 2002 01:31 AM
hyperactive
Jan 1, 2002 02:29 PM
supercivic01
South
Nov 30, 2001 11:27 AM
