Electrical Problem
Old Oct 23, 2012
EJ_6's Avatar
EJ_6 is an unknown quantity at this point
Exclamation Electrical Problem
hi guys, im having this weird and irritating electrical problem... I've been searching online and in other forums to see if anyone else has had the same problem but it seems like no one else had.
Bought this non running 97 hx with a b16 block and gsr head, pulled that out and swapped in a y7... I go in to turn the key to the Accessories "I" position and i dont have power to the radio and cigarette lighter, i check the 75a fuse under the hood and its good.. Turned the key to the ON position "II" the radio and cigarette lighter turns on....the third position which is the start position the lights on my dash turns on, it was suppose to turn on on "II". basically everything on the ignition is moved over one.
already did
-ignition switch..also tried turning it manually.
-main relay
-fuses
Old Oct 23, 2012
lazlong's Avatar
Re: Electrical Problem
Find a service manual and check the pinout of the ignition switch.
CarStuff
Dec 6, 2020 12:52 PM
juror
May 26, 2015 06:35 PM
steveneddy
May 19, 2015 02:39 PM
ywgflyer
May 15, 2015 05:05 PM
Ronin
Nov 17, 2001 09:46 PM
