Temperature problem
Old Jul 28, 2012
marcus1991's Avatar
marcus1991 is an unknown quantity at this point
Temperature problem
My car was parked up for about 2 months, so i decided to give it a run....after driving for about 8km, i saw the temp gauge went up to 3/4......i recently changed the water pump an the gauge temp sensor so i know thats not the problem....i took out the thermostat an drove the car and the same thing happened....the gauge does not go higher than 3/4....i also have my fan on all the time.....my engine is a d15 non vtec..
This only happens when i drive for more than 8km...
Can this be a radiator problem?....
Someone help me plzz...btw, am not losing any coolant...
Old Jul 29, 2012
project5k's Avatar
project5k is an unknown quantity at this point
Re: Temperature problem
if you changed the sending unit for the temp gauge, the wrong one could cause bad readings on the dash. You may not actually have a problem, but just the wrong/a bad sending unit.
Old Jul 29, 2012
did you open the hood and put your head in under there? usually it will be very obvious when a car is running hotter than normal. you may just have air in the system giving a false temp reading if you did not bleed it after doing the waterpump, or you could have clogs in the cooling system (radiator or heater core).
Bruce.Ringler
Jun 18, 2015 08:12 AM
cruisers10
May 12, 2015 10:46 PM
Rushfan1
May 6, 2015 01:20 PM
hokiedad4
May 3, 2015 10:06 PM
aultman1990
Apr 19, 2015 07:14 AM
