Very Very rough Idle HELP ASAP!!! PLEASE!
Old Mar 25, 2012
MrFirewolf1000's Avatar
MrFirewolf1000 is an unknown quantity at this point
I have a 2000 civic ex D16y8 turbo. It has the edelbrock turbo kit on it. I have posted a video on youtube. here is the html.
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1212& transactionid=1332721054-2415162187&posted_by=MrFirewolf1000_www.civicforum s.com&youtube_video_id=NgquiZPO-Ic[/autostream]
please check it out and listen and see what your thoughts are. Id really mean a lot. i miss driving my boosted civic. way to much fun not to drive it. but anyways on to the issue. car starts just fine but has a rough idle as shown in video pulsating sound. I just installed a new dizzy no luck. then the car will eventually want to start to go down on rpms and eventually wants to die. if i give it some gas it will run but even then almosts stumbles on itself and wants to die but then if i give it enough gas or keep revving it and then hold the rpms up it wont want to die on itself. Also if you need more details I will do my best to give you what i know.
thanks,
tim
Old Mar 25, 2012
513EM1's Avatar
Naturally Aspirated
513EM1 is an unknown quantity at this point
Re: Very Very rough Idle HELP ASAP!!! PLEASE!
https://www.civicforums.com/forums/3...e-posting.html
Go through this entire list. There is a number of things it could be.
Sounds like its most likely the FITV if you have a loping idle. That or the TPS.
Old Mar 25, 2012
Sorry about that 513EM1. And also thank you. I will check out that post and also look at the FITV and just buy a new TPS.
Old Mar 25, 2012
513EM1's Avatar
Naturally Aspirated
If your not sure of the problem, and you dont have a vacuum leak, try picking up a used throttle body from a junkyard, craigslist, or ebay.
Thats another option if you dont want to go replacing sensors one by one.
Old Mar 25, 2012
Ok. I seen someone else talking about buying a used one at a junk yard. Ill look into it and see if the junk yards near me have gotten any civics with motors left in them. Ill try cleaning the FITV also.
SimpleUser
Apr 24, 2021 02:54 AM
JDMnoob
Aug 2, 2015 02:38 PM
1khilari
Jul 9, 2015 08:12 PM
