97 starting issues
Old Mar 7, 2012
impulsed22's Avatar
slammit
impulsed22 is an unknown quantity at this point
97 starting issues
I picked up a 97 civic and when I got it, it had a snapped timing belt. I've replace the timing belt and have been working on getting the car to start, this is where I've run into issues. At first I thought it was just the battery(it was sitting around for about a year, and the battery was bad when I had it tested) but that did not fix the issue. I jumped the starter and it turns over just fine. The fuel pump pumps and the main relay clicks when the key is turned over. It just seems like no power is getting to the starter at all. I was thinking maybe the wires going into the starter could be bad. But I'm not sure...the wires all look good the grounds on the engine and the battery connectors are all clean and tight. I'm just stuck at this point.
Old Mar 7, 2012
Re: 97 starting issues
When you say "jumper", do you mean a jump start, or shorting across the terminals of the starter?
Wiring diagram and a test light.
Test, don't guess.
Once you get it to crank and it still won't start, do a compression test.
I bet it bent valves when the timing belt let go.
HTH
Old Mar 23, 2012
impulsed22's Avatar
slammit
i finally found the issue, it was the clutch saftey switch...took a lot of digging around and testing wires but it fires right up now...
ayoitzjulesdx98
May 13, 2015 08:31 PM
jetcare101
May 8, 2015 01:33 PM
civic_gt
Apr 19, 2015 08:15 AM
black2k1vtec
Dec 6, 2001 09:49 PM
