Emissions HC and NO FAIL! 2000 Honda Civic Si
Old Dec 14, 2011
VoiceEternal's Avatar
VoiceEternal is an unknown quantity at this point
I need help figuring out what's causing my 2000 Si coupe to fail the emissions.
I just had the entire exhaust system redone within the past 6 months: new cat, new muffler, new center pipe.
I had an engine swap done as well just recently. The original D16Y swapped out for a leaner running JDM engine model D15B. The engine itself is clean and I had a flush done and oil changed just 400kms ago. Timing, spark plugs, and vacuum hoses were checked as well and all seems fine.
I checked the air filter, which turned out to be fairly dirty, and I'll be replacing before the retest, but otherwise, I'm at a loss.
PLEASE HELP!!
Old Dec 14, 2011
lazlong's Avatar
Re: Emissions HC and NO FAIL! 2000 Honda Civic Si
High HC is caused by:
1. loss of compression
2. weak spark
3. running rich
Check those and post back.
jessicakaybby
Apr 20, 2015 12:11 PM
gabrown2
Apr 11, 2015 08:22 PM
bahena08
Apr 11, 2015 05:09 PM
liljoe
Nov 4, 2001 01:27 PM
