Trick to installing radiator hose???
Old Nov 5, 2011
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
I'm replacing the lower radiator hose and though installing the bottom portion isn't a problem, the upper end is. I can't even get 1/4 of it installed.
Any of y'all know of any tricks installing the radiator hose? I was thinking of dipping the end in boiling water to help soften/expand the hose.
What do you think?
Old Nov 5, 2011
lazlong's Avatar
Re: Trick to installing radiator hose???
Lube it?
Old Nov 5, 2011
Nosepicker's Avatar
Okay, got the top part in but lower end is a PITA!!! Spent hour or so pulling and wiggling and only got 1/4 of it in. Lubed the inner tube and outlet and still no go. The OEM hose inneris so freakin' small/tight it just won't slide over.
This sucks!
Old Nov 5, 2011
try lubing it with coolant. is it an oem hose? i just did this on the accord with an aftermarket hose (good quality) and it went in no problem after a bit of wiggling. sounds like yours is too tight or something. you shouldnt be forcing it on because that can cause other problems. you could also try dipping the hose in boiling water that will cause it to expand.
Old Nov 6, 2011
Nosepicker's Avatar
Yeah, it's OEM. I dipped both ends in boiling water and it helped a little. And I tried lubing it with coolant too. I got it half way in and said, "Screw it...I'm clamping it and calling it a night!!!" 3 hours trying to squeeze the radiator hose in!
Screw you Honda! Honda's are such a PITA to work on. Everything's so compact and you have to take off a billion parts just to get to that one part. And it's the same with their motorcycles.
Old Nov 6, 2011
note to self, buy aftermarket hose next time i need to change em. i think im overdue already at 100k miles.
Old Nov 6, 2011
lazlong's Avatar
In my opinion, they don't need to be changed until they break.
Old Nov 6, 2011
Nosepicker's Avatar
In my case I believe the old rubber end and clamp lost it's elasticity/tightness...whatever you want to call it. With the new hose and it's tight@$$ end I don't expect it to leak. I really hope this doesn't come back and bite me in the @$$...and discover it wasn't the hose but something else causing the coolant leak.
Old Nov 6, 2011
yeah i really hate replacing something thats not broken, but after seeing how the hose just blew up on the accord (also around 100k) and almost lost all the coolant while driving, idk. the hose seemed fine too no cracks or damages. my civics TB coolant hose (the small one) when out really early around 30k miles so i replaced that with a stronger fuel injection hose that is much harder. the plastic holder dug into the stock hose over time and finally poked a hole. so far the fuel injection hose held up fine all this time. im very nervous about coolant either being lost or something like the thermostat not opening and the engine overheats. that coolant gauge is useless too because i dont think i would ever notice anything. we dont even have a dummy light for overheating.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Sarahwv2910
22
Jun 17, 2015 12:35 PM
Mercilus
Jun 7, 2015 10:00 PM
Lunar
May 22, 2015 07:43 AM
deus-ex
Apr 13, 2015 12:29 PM
