2000 civic shaking and vibrating
Old Oct 30, 2011
nickrolando's Avatar
nickrolando is an unknown quantity at this point
Im from new york. we had 7 inches of snow yesterday. I drove the car earlier in the day for a little while and it was fine. i took a ride last night for 15 minutes to bank and back home. after leaving bank car was shaking but not horribly at low speeds. went to go on parkway this morning and from 40 mph and over it was shaking horribly and vibrating. i had to get off parkway and go home.
Anyone have any ideas?
thanks alot.
Old Oct 30, 2011
JohnHenry's Avatar
R.R. Adict
JohnHenry is an unknown quantity at this point
Re: 2000 civic shaking and vibrating
Hmmmm, possibly between snow and salt creating slush- it may have built up under your vehicle, wheel wells, etc.... Without you hitting something, appearent impact-- and just a short easy going trip its hard to say what it is.... Also involved with vibrations-suspension, engine mounts, and blancers...
Old Oct 30, 2011
so maybe when i get home from work, check out under the car for snow and all that type of stuff and try to kick it all off?
Old Oct 30, 2011
JohnHenry's Avatar
R.R. Adict
Thats your best bet IMO with description at this point. I live in Texas now, but born and raised in Western NY where snow came alot and I've seen the snow build up as described.
Old Oct 30, 2011
thanks for the heads up. ill check it when i get home. i did do some donuts in a parking lot and then it started happening lol
Old Oct 30, 2011
JohnHenry's Avatar
R.R. Adict
Aaaaah, now that opens the window to possibly other problem(s) may have occured.... I hope its built up snow, good luck!
Old Oct 30, 2011
snow or ice inside the rim will cause major balance issues and shaking til it melts. sometimes if it freezes, it can be very hard to get off esp with steelies where you have to clean it out from the back side.
Old Oct 30, 2011
bfairweath's Avatar
bfairweath is an unknown quantity at this point
Gearbox is likely correct. I live in Wisconsin and have had this problem with my Civic on several occassions. Snow or ice on the inside of the rim throws off the balance something fierce.
Old Oct 31, 2011
dailydriverEX's Avatar
dailydriverEX is an unknown quantity at this point
It's just snow turn to ice on your rim. have this all the time here in Wisconsin. Go home and melt snow and you are good.
Old Nov 2, 2011
Matt C's Avatar
Honda Noob
Matt C is an unknown quantity at this point
i'm getting a shaking/vibration at low speeds like when i take off from a stop sign or light.... no snow here in Delaware. any ideas? i got a feeling it's the mounts or possibly the tranny (which is getting flushed soon).
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
