No Spark and Can't figure out!
Old Oct 10, 2011
AgentSi's Avatar
AgentSi is an unknown quantity at this point
Long story short I had to rebuild my motor (b16a2) cause of problem with the head, so went to do it from the bottom up. We put the motor in and I have fuel but no spark. It cranks over but no spark. I have no check engine light when in the ON(ii) position. Now the car started up fine before we did the rebuild, and the dizzy work with out a problem, I put new plugs and wires on, I ground everything even G101 ground. I have tested the coil and the ICM and they give the proper readings via the Honda Service Manual. And still nothing! I am leaning to a bad dizzy, but like I said everything worked before the rebuild. So could the dizzy be bad for just sitting off the car for 2 months? What is your thought?
I have search on the forums here and every possible place online and can't figure it out. I have no spark and no cel light (which worked before also).
Thanks for any help!
Old Oct 14, 2011
rb25al's Avatar
rb25al is an unknown quantity at this point
Re: No Spark and Can't figure out!
Check fuse no 15(alternator sp sensor. its 7.5amp)you might have trapped a wire somewhere causing a short.
I done it last week.
hope you get it sorted
Al
Old Oct 16, 2011
AgentSi's Avatar
Al
I have check that fuse the other day and fine. I don't think I have anything trapped. I wired everything except the tranny connections before the motor went back in the car. Thanks for the help.
Old Oct 19, 2011
AgentSi's Avatar
280 dollars later and I was the distributor! even though all the volt and ohms check out, I just went and got a new one and now I have spark.
SimpleUser
Apr 24, 2021 02:54 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
jzhartman
Jul 9, 2015 04:56 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
CivicsClass101
Jul 9, 2015 11:14 AM
