Check engine light... Misfire?
Old Sep 19, 2011
p7C's Avatar
p7C
p7C is an unknown quantity at this point
Exclamation Check engine light... Misfire?
Ok so my check engine light came on last week and my car started running really boggily and sometimes itll have no power and the check engine light will flash ill give it more gas and after a bit the light will quit flashing but stay on. So i just got the time to get it checked out at the local auto part store and the computer said one or more cylinders were misfiring or my EGR valve was open? I then went to get new tires put on and i was talking to the guy there about it and he said that its most likely niether of them problems and most likely my catylitic converter is clogged.????
99 civic ex
Old Sep 20, 2011
MatthaiN's Avatar
MatthaiN is an unknown quantity at this point
Re: Check engine light... Misfire?
If your catalytic converter is clogged, it will cause those types of problems that you are describing as well as screwing up your O2 sensor soon enough if you let it go unchecked. Take it to an exhaust shop. Most will diagnose for free. At least in my state.
Old Sep 20, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
my buddy has a 96 ex and his pulled of those same codes and we replaced the coil which it wouldnt hurt to get your cat cleaned then it would give you more power and better fuel mileage
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
ashleymmackey
Apr 18, 2015 09:48 PM
deus-ex
Apr 13, 2015 12:29 PM
