I need help with my 98 Civic LX
Old Sep 10, 2011
Bandaidgrenade's Avatar
Bandaidgrenade is an unknown quantity at this point
Exclamation I need help with my 98 Civic LX
Hi. I have a problem with my car. I recently bought a 98 civic. I went to get it inspected and they told me to run it through a drive cycle and come back since I have 3 codes that aren't ready. The Cat, O2, Evap. I drove it for about 5 to 6 minutes at 50 on the freeway. But when I got off the freeway and was heading home the car just shut down. No check engine light showed up until it died. Finally after about 15 minutes we got it started again. But now everytime I drive it to get it inspected it dies. I've replaced the distribitor, did a coolant flush (since the person I got it from decided to use water), replaced all the fuses, replaced the spark plugs, got a new upper o2 sensor, plug wires are like new and so is the batterey. After doing all of that it just died again while trying to run it through a new drive cycle. I'm very confused onto what could be causing it to die. If someone could help me out that would be great.
Old Sep 11, 2011
Exclamation Re: I need help with my 98 Civic LX
I'm so confused to what is going on. It's not the starter since it actually starts. It's not overheating. It's not the timing since it runs really nice when it does run.
What else is there?
Old Sep 11, 2011
cetcivic's Avatar
cetcivic is an unknown quantity at this point
cat clogged? do u smell eggs?
Old Sep 11, 2011
No egg smell. When it runs it smells fine and runs fine. That's why I'm so confused.
Old Sep 11, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
So all 3 codes are still present after replacing the O2 sensor? Did you get your alternator tested?
Old Sep 11, 2011
No, I didn't think that the car would run right if the alt is bad. But I'll give it a shot.
Old Sep 12, 2011
cooncatcher19's Avatar
cooncatcher19 is an unknown quantity at this point
it may be your ignition coil cause when your car gets to running temp the coil may be grounding out and the car will cut off and its a pain to get it restarted until the motor cools down but the car will run fine off a cold start and drive fine but when you let off the throttle when its warmed up enough the car dies so look into the ignition coil see if that helps
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
