How tight should the o2 sensor be?
Old Aug 7, 2011
SteelBlueTJ's Avatar
SteelBlueTJ is an unknown quantity at this point
I replaced the upstream o2 sensor on my 99 LX. The sensor is kind of a pain to get to with the A/C lines in the way, but still managed it. I bought one of those o2 sensor sockets and it worked great to remove the old sensor, but was useless installing the new one. I couldn't even get it to seat properly on the new Bosch sensor since it is longer than the opening on the socket. I managed to tighten it all the way by hand and got maybe one turn on it with the ratchet and o2 socket halfway on the sensor nut, enough to get a bite. It feels good and tight. I hope that it good enough. It's just a tight space to work in.
Old Aug 7, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: How tight should the o2 sensor be?
im pretty sure that its tight enough and it will get a little tighter after it gets hot and cools off
Old Aug 7, 2011
should be fine, you can also use a regular wrench on it. so long as it is seated properly so air doesnt leak in.
reddawnman
Engine DIY
224
Jun 3, 2023 10:02 PM
Redviking
Engine DIY
44
Sep 8, 2018 02:58 PM
DaMadScientist
Engine building
16
May 17, 2017 02:05 PM
CivicsClass101
Jul 9, 2015 11:14 AM
nefraa
Aug 8, 2012 11:45 PM
