Civic won't start only hears a click
Old Jul 27, 2011
whatsup's Avatar
whatsup is an unknown quantity at this point
Hi all. Came here to ask for help as I'm having trouble with my civic esi
Couple of things I should mention:
* CEL before turns off in 1-2 seconds but when I haven't used the car for awhile or when weather is cold it takes up to 2mins. Worst is maybe 5-7!
* I replaced the battery just last May and it worked fine since, no trouble
* Didn't use the car for maybe 2-3 weeks and CEL takes awhile to turn off and engine won't start at all, only hears a click. My friend advised to step on gas and that worked. Took the car for a drive and it worked well didn't have a hard time starting it again.
* Didn't use the car again for about 2 weeks and it won't start at all even when I step on gas. Only hears a click. Nothing.
I don't wanna go to some mechanic or shop I don't know in worry of being ripped off as I obviously has no idea. I just need someone who can really help. My friend said it can be the starter but some forums mentioned it can be a corroded battery connection/connector and I am trying to avoid spending on something that will not solve my car trouble. If you all can give me some advise so I know how to better deal with this, I'll appreciate it.
Thanks!!! Please help!
Old Jul 27, 2011
Re: Civic won't start only hears a click
at least get the code read for free at the auto store to see whats wrong.
Old Jul 27, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
most likely ur starter
Old Jul 28, 2011
whatsup's Avatar
it was the starter...it started today but the CEL still took about 4 minutes to turn off.
After I started it and drove it around and shut off the engine, I started it again and the CEL only took a second to turn off. Should I take that to electrical or something like what the other guy said and have the code read?
Old Jul 28, 2011
turbo_coupe_EJ1
i would take it to autozone and get them to run the tester on it and find out what it is and plus its free
Jonnie.
Jan 13, 2019 11:21 AM
vtec92
May 4, 2017 03:20 AM
Richkid23
Apr 19, 2015 12:53 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
