Sonar projector headlights
Old Jul 25, 2011
importgirl1990's Avatar
importgirl1990 is an unknown quantity at this point
Exclamation Sonar projector headlights
so i have a 96 civic with "h1vol sonar sk3301-cv99 sae ahri3992 dot" projector lights. i need to find an adaptor to plug into the stock wiring harness so i dont have to tap into the wiring harness itself. does anyone know if one exists?
Old Jul 26, 2011
Re: Sonar projector headlights
i assume you want H4 connector? the stock plug is a female H4. so you want a male h4 to plug into the stock connector. then you can tap the wires from the male plug to the projectors. these are very good quality
http://www.comagination.com/parts.htm
and you want the one that says "H4 / 9003 Male plug connector pigtail - Heavy duty short plug with secure double barrel crimp connectors on wire and insulation. 18 AWG stranded wire (max 16 amps) about 6 inches long. A 100 watt halogen bulb uses about 8 amps based upon 100W / 12.5V = 8A. Fits standard H4 / 9003 female socket. US$6.69 (Quantity 2) [in-stock] High heat resistant."
wingsfan19
Oct 1, 2015 03:45 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
