5sp Transmission Problem - 98 Civic EX
Old Jul 16, 2011
65Stang's Avatar
65Stang is an unknown quantity at this point
I have a '98 Civic EX with a 5sp manual transmission with just over 200k miles. I have had no issues or noise or vibrations from the transmission. While driving onto the freeway, the tranny jumped out of 4th gear and now I can't engage any forward gear. I do get some gear clash while trying to engage reverse now, but nothing else. The clutch is fairly new and seems to be working properly.
Any ideas on what's wrong with the tranny?
Vic
Old Jul 16, 2011
MelJ's Avatar
Trance Addict
Re: 5sp Transmission Problem - 98 Civic EX
Bent shift fork and/or worn synchronizers. When you enter reverse, the car should be fully stopped because reverse isn't synchronized in our transmissions. Even the slightest amount of movement will give you a clash.
Old Jul 16, 2011
65Stang's Avatar
I figured it was an internal linkage problem. Now the $100k question, do I pull out and down, order the parts to repair or replace it with a $350 used tranny that I have found? It's my commuter car and while its down I have to drive my truck which eats gas. If I R&R with the used tranny, I could have it back on the road by Monday. I'm worried that I'll see more wear/damage once I get inside of this old tranny.
Vic
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
Rinzlor
Apr 24, 2015 10:33 AM
Richkid23
Apr 19, 2015 12:53 PM
Russps
Nov 8, 2001 02:00 AM
