98 Civic - 2 Distributors in 6 months
Old Jul 1, 2011
Frank040's Avatar
Frank040 is an unknown quantity at this point
1998 Civic DX Hatch, 202k<O</O
12/2010 - car stalled, towed to garage, mechanic replaced distributor cap assembly ($340/part). 6 months later, same thing. Mechanic didn't charge for anything, said part still under warrantee. Claimed both parts new, not rebuilt. I looked up part at Majestic Honda - part is made by TEC-WESTEC. <O></O>
No other problems with engine, good idle and accelleration, does not burn oil.
Anybody have any idea what could cause a distributor to fail after only 6 months??
Thanks,
Frank P.<O></O>
<O></O>
Old Jul 1, 2011
lazlong's Avatar
Re: 98 Civic - 2 Distributors in 6 months
-With the ignition OFF, remove the cap, rotor, and the leak cover (under the rotor). Then disconnect the wires.
-Turn the ignition to ON and check for battery voltage at the black/yellow and white/blue wires.
How much voltage are you getting at each wire?
Old Jul 1, 2011
BlueEM2's Avatar
Whachya lookin at?
Check voltage but my bet is the second dizzy was faulty.
Old Jul 2, 2011
Frank040's Avatar
OK, Thanks Lazlong.
Checked all 4 wires going into Dist:
Yellow/Green= 11 volts
Yellow/thin green = 12 volts
Black/Yellow - 12 volts
Blue = 12 volts
The 11 volt wire is yellow with green stripe, other yellow wire has very thin green stripe.
1st 3 wires are in a row at the bottom, blue is on the side.
Thanks and Happy 4th
Old Jul 2, 2011
lazlong's Avatar
OK, now disconnect ECM/PCM connector A(It's the only 32 pin connector) and check continuity(Ohms) of the yellow/green wire from dist to ECM/PCM. There should be continuity.
Check continuity from the yellow/green wire to body ground. There should be no continuity.
Check for continuity from the white/blue wire(dist) to the test tachometer connector:
Check for continuity from the white/blue wire to body ground. There should be no continuity.
If all tests are normal replace the ICM (Ignition Control Module). It's number 7 but, you would have to buy the whole housing( number 4): http://www.hondapartscheap.com/south...t=0&quantity=0 Or this place has 'em as cheap as $36: http://www.rockauto.com/
File Type: jpg
Old Jul 2, 2011
Frank040's Avatar
I don't understand: If all tests are NORMAL, then replace ICM? That's the same part that was replaced a few weeks ago by mechanic, part #4 on the hondapartscheap link - "Housing, Distributor" @ $236. ICM is part of the distributor assembly??
Thanks again
Old Jul 2, 2011
lazlong's Avatar
Which is it? Did you replace the cap assembly or the whole distributor?
Old Jul 3, 2011
Frank040's Avatar
Whole distributor, Illustration 4 on these sites:
http://www.hondaautomotiveparts.com/...C+-+WEASTEC%29
Old Jul 3, 2011
lazlong's Avatar
I don't really know what it could be, unless you're getting too much voltage going into the dist and it's burning it up (and we already tested that and it's getting battery voltage). I do know that these dist are notorious for going bad, you may have just got 2 bad ones in a row.
Old Jul 9, 2011
Frank040's Avatar
1st dist went bad after 190k miles - 2nd went bad 6 months after. Could be that Honda doesn't make a replacement dist for '98 models is causing this problem? Anyway, I'm seriously thinking of keeping a new dist in the car when and if this one goes.
Old Aug 15, 2011
liljoe97ex's Avatar
liljoe97ex is an unknown quantity at this point
well i have replaced mine myself and they broke on themself twice, so i had my mechanic do it. And i also bought shitty ones too so that also might be the problem.
Old Sep 28, 2011
supraman1990's Avatar
supraman1990 is an unknown quantity at this point
wow... im now getting a gut feeling on just going aftermarket when it comes to the distributor... instead of going remanufatured
Old Nov 17, 2011
Newtothegame's Avatar
Newtothegame is an unknown quantity at this point
I heard aftermarket distributers go as fast as manufactured ones lol. Idk if it's true or not but that's what I heard
Old Jun 8, 2014
RobertBurnsOB's Avatar
RobertBurnsOB is an unknown quantity at this point
My mechanic installed a new distributor in my 1998 Honda Civic XL 2 months ago, replaced it about 2 weeks ago on warranty, and replaced it last Friday on warranty. All 3 replacement distributors were installed new.
BREADFAN
Apr 15, 2015 08:58 AM
deus-ex
Apr 13, 2015 12:29 PM
gabrown2
Apr 11, 2015 08:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
