96 hatchback shift linkage question. Answer found. Lock thread please.
Old Jun 28, 2011
FlatBlactHatch's Avatar
Yes i know, it should be a "k"
FlatBlactHatch is an unknown quantity at this point
I took out a 5spd tranny out of a 98' 4 door.. I was told it will fit.
The torsion bar dropped with no problem.. but when removed the nut from the shift linkage bolt would not slide out no matter what
so I just sawed the bar off. Now... do i just cut and reweld it to the bar thats attached to the tranny im putting in. Or can it be removed at the tranny end? not where the arrow is but the other linkage.. can it be removed from there someowheres? i noticed its pressed there. Or unless hauling back the rubber sleeve exposes another way to change it.
Old Jun 28, 2011
Re: 96 hatchback shift linkage question.
I found the answer here(with pictures):
http://www.honda-tech.com/showthread.php?t=2018600
97-DX-Lover
Jun 14, 2015 06:07 PM
Blazz
Jun 4, 2015 01:04 AM
h4ldol
Jun 3, 2015 03:26 PM
shindrome
Exterior
May 5, 2015 02:50 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
