2000 civic lx driver side mirror & window
Old Jun 5, 2011
jatzert's Avatar
jatzert is an unknown quantity at this point
need to replace the driver side view mirror. How do you pull the side panel off? Also the driver side window motor is slow and window won't go up without pulling on it. Thinking I need to replace the window motor. How hard is that? Could it just need lubricaton?
Old Jun 7, 2011
JackedByJack's Avatar
JackedByJack is an unknown quantity at this point
Re: 2000 civic lx driver side mirror & window
ok so you want to unscrew and screws on the door panel like the one hiding by the door handle. then after that there all pop locks you just grab a flat head and slide behind one of them and pull the door panel and push the on the flat head at the same time. it probably needs to be replaced pop the door panel off then watch it and see if theres any noticeable problem. if not hit a junk yard and replace it. for better instructions download a pdf of your cars mechanics book it will help a lot
ej8
Apr 13, 2015 06:36 PM
tattedlariat
Apr 12, 2015 07:55 PM
mwwhonda
Nov 7, 2001 07:24 PM
EXWisdom
Nov 5, 2001 10:24 PM
sonsonzai
Nov 4, 2001 12:52 PM
