96 ek clutch problem
Old May 26, 2011
96ek1983's Avatar
96ek1983 can only hope to improve
Hey peeps I have a 96 hx coupe and I replaced the clutch and flywheel and and blead the system so I don't know what else to do but to adjust the clutch pedal but the car still slips can anyone help out please?
thanks
Old May 26, 2011
MelJ's Avatar
Trance Addict
Re: 96 ek clutch problem
Are there any adjustments that need to be done? I've never done anything as complex as a clutch replacement, so I don't know personally. Just throwing out a suggestion. Did you get any type of contaminant on the disc itself? Maybe the contaminant glazed the clutch disc in the process of driving? Glazing goes away though, but if its been doing it for a while, i'd suspect installation error. I'd just hate for you to have to go through all that again.
Old May 26, 2011
iSharix's Avatar
iSharix is a jewel in the roughiSharix is a jewel in the roughiSharix is a jewel in the roughiSharix is a jewel in the rough
Fail, you posted in the wrong forum !
Old May 26, 2011
96ek1983's Avatar
I was told possibly I could adjust the clutch pedal but Idk what it was is that I replaced the clutch first because the flywheel didn't look glazed or burnt and after that it was working for about two weeks not slipping. Then I replaced the flywheel and it worked for about a week and its still slipping and the reservoir is full and I blead the system again thinking it still had air but nope. So Idk.
Old May 26, 2011
MelJ's Avatar
Trance Addict
Air in the system wouldn't cause the clutch to slip. It would only affect pedal feel and travel.
dinsum
May 28, 2015 09:30 PM
pantdino
15
May 13, 2015 02:22 PM
crowtoo
May 11, 2015 06:50 PM
CaptainAmerica
Feb 3, 2002 09:36 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
