NEEWWWWBBB! I have a few issues with my 1996 Dx Hatch
Old Apr 19, 2011
karlisdad's Avatar
karlisdad is an unknown quantity at this point
<P>Ok, i have to do a drivers side CV shaft and the timing belt. No problems there, im confident in the resorces available ill get that done without issue, however my car wasnt equipt with a factory Tachometer and my current cluster the Speedo and odometer&nbsp;only work about half the time. </P>
<P>&nbsp;</P>
<P>*SO, i found an Ex cluster with a tach and i want to install it but is there going to be wiring&nbsp;harness issues with adding &nbsp;the tach cluster?? </P>
<P>&nbsp;</P>
<P>*Whats the best way to get the crack pulley off on the D16y7?</P>
<P>&nbsp;</P>
<P>*Any special tools required for either job?</P>
<P>&nbsp;</P>
<P>&nbsp;</P>
<P>Thanks in advance!<IMG class=inlineimg border=0 alt=0 src="https://www.civicforums.com/forums/images/smilies/rockwoot.gif" smilieid="53"></P>
Old Apr 19, 2011
justpassingthru's Avatar
justpassingthru is an unknown quantity at this point
Re: NEEWWWWBBB! I have a few issues with my 1996 Dx Hatch
Just did timing belt. To remove the crankshaft pull, you will need a special tool. You can also get them at some autoparts stores - I got mine at CarQuest. There are other alternatives, but this made it painless with my 150psi air compressor.
Do a search - there is tutorials on how to do your timing chain.
No input on the cluster, sorry.
Old Apr 19, 2011
karlisdad's Avatar
definately need some info on that cluster swap, help help help. lol
Old Apr 20, 2011
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
If it's anything like my 94, it's a straight swap. The tach is already wired. Plug and play.
TiggerDX
Jun 18, 2015 01:43 PM
Aball93
May 16, 2015 10:11 AM
darwin-t
Apr 18, 2015 09:29 PM
NROD315
Apr 16, 2015 08:40 AM
ayzan
Bolt-on Engine Performance
Dec 12, 2001 10:45 AM
