Car shut off
Old Apr 16, 2011
BearTheGreat's Avatar
BearTheGreat is an unknown quantity at this point
Car shut off
Was driving down the road and car shut off. When it goes to start it it sounds like it starts but dies agian. What could be the problem?
Old Apr 16, 2011
MelJ's Avatar
Trance Addict
Re: Car shut off
It could be the ignition switch. Honda issued a recall for that generation of Civics. That sounds exactly like the behavior described in the recall.
Old Apr 16, 2011
Re: Car shut off
Where can i find that part.
Its starting just shuts right back off
Old Apr 16, 2011
MelJ's Avatar
Trance Addict
Re: Car shut off
The dealer should replace it for free IIRC. I don't know exactly how they deal with recalls though. I've never actually shopped for anything like that, but I guess you can check your typical places like Auto Zone or Advance Auto or any similar place of that sort. I'd still call your local Honda dealer and have them check it out.
Old Apr 16, 2011
Re: Car shut off
Could it be my map sensor?
Old Apr 16, 2011
MelJ's Avatar
Trance Addict
Re: Car shut off
You have a 95, so you might not have OBDII though. Is the car throwing any codes? I still think it's the ignition switch, but troubleshooting never hurts.
Old Apr 16, 2011
Re: Car shut off
Its a 96 OBDI i think they guy that put mine together put the wrong kind of map sensor in mine. Greddy t3 turbo also a vtech um not sure what else might have wrong distributor in it to.
Old Apr 16, 2011
MelJ's Avatar
Trance Addict
Re: Car shut off
Okay, you already know where the sensor is, so I'll give you the other stuff.
You need to locate the PCM. I don't know the circuit numbers off hand, but the colors for the wires are as follows:
Yellow/Red is the power wire
Green/White is the ground wire
Red/Green is the signal wire to the PCM.
You're going to want to disconnect the sensor. Turn the key on. Not the engine. Just cycle the key until it gets to where you can use all the accessories.
Take your pins and check for voltage between the power and ground wires. You'll want to place your pins in CAREFULLY as you can damage the wires. Don't stab them into the wires. Just place the pins in behind the wires. You've been warned. Just take your time. Turn on your voltmeter and check the voltage. You should have 5 volts. If it's lower than that, your sensor wires may be bad. Any fellow forum members wanna help me out? I think I covered a good chunk of the test, but I think there is another part that I'm missing right now.
Old Apr 16, 2011
Re: Car shut off
What if it isnt the wires it the map its self?
Old Apr 16, 2011
Re: Car shut off
alright, first off the first thing you need to tell on the first post is that you have a turbo.
if it's the map itself, well, you need to take the car to a shop with a dyno and talk to them and try to figure it out first. no online help will work at this stage.
Besides that, just try what MelJ said first and if that does not work, follow the above. No point in mental masturbation of "what if?" at this point.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
TropiKalCiviC
Nov 8, 2001 10:13 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
