00 Hatchback idle prob, stalls, going crazy
Old Mar 28, 2011
Tavon_N's Avatar
Tavon_N is an unknown quantity at this point
I have a 2000 civic dx 70,000mi. no cel, starting is no problem, its only when i stop. the car idles erratic (does this all the time in the summer, and when its cold it does it less or not at all) sometimes it will go up and down for a long time, when this does happen it sputters on take off, and sometimes it just dies at a stop after struggling to stay idled
What i changed so far: plugs, plug wires, dizzy, fuel filter, both o2 and cleaned out my iac valve
I've been reading a lot of other forums about this same problem, but cant find a solution for this problem and im too broke to be fixing parts that are still good. Can someone help me with this one, Thanks!
Old Mar 28, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: 00 Hatchback idle prob, stalls, going crazy
Probably something going on with your injectors, clean em!
Old Mar 28, 2011
Tavon_N's Avatar
the injectors were replaced a year ago, so it cant be them...
Old Mar 28, 2011
Firearmor's Avatar
Firearmor is an unknown quantity at this point
There is a air mixture type screw on your throttle body that you can adjust that should take care of your problem. Just be sure to only adjust it when the car is completely warmed up. You want to loosen the screw so that the idle adjusts up.
cizsak
Jul 21, 2015 03:39 PM
NoobyKid
Jul 13, 2015 07:53 AM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
92hatchbackcx
Jul 7, 2015 08:23 AM
