CEL after fast accel.
Old Mar 21, 2011
Civic_EX00's Avatar
Civic_EX00 is an unknown quantity at this point
CEL came on in 4th gear at about 3500 rpms .. car bucked then light came on and hasnt gone off since... any ideas as to what could be the cause? just had cat converter and o2 sensor replaced...
Old Mar 21, 2011
MelJ's Avatar
Trance Addict
Re: CEL after fast accel.
Go to Advance or Auto Zone and see if they can pull the codes for you. What CAT did you get? Those aftermarket ones are garbage and there's a reason they're so cheap. But yeah. Get the code(s) and post 'em up so we can help you out.
Old Mar 21, 2011
Civic_EX00's Avatar
i got the cat at an automotive center, 830 dollars to have the thing fixed... car stalled out on a main street, i changed the oil, started up again to make it to my house and my car wouldn't start at all when i went out the next day. had it towed to the automotive center, they did a complete diagnostic check, put in R&R cat converter and R&R o2 sensor. the CEL was on when i bought the car, was told it had to do with the killswitch, which im almost positive it doesnt... i'm at a loss.
Old Mar 22, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
bucking and stalling are indicative of misfiring, so I would start by looking at the cap and rotor, plug wires and plugs as the first source. I recently ran into this on my own car and ended up finding that the previous owner had overtightened the cap screws and had broken 2 of the 3 of them causing the cap to be loose and misfire and basically do exactly what you described. Sounds to me like you mechanic does not know his head from his *** so lets start with the basic and get your car fixed together.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
solarpunk70
Apr 12, 2016 11:43 AM
Luluharp
Sep 27, 2015 11:56 AM
Mannimarco
Sep 7, 2015 10:01 PM
jpat21
Sep 3, 2015 11:32 PM
