99' LX starting and stalling issue
Old Mar 17, 2011
lohnes68's Avatar
lohnes68 is an unknown quantity at this point
Question 99' LX starting and stalling issue
Ive got a 99' civic lx, for the past few months it has been stalling on me while driving, mainly through town or something. and then when i try to start it back up i have to try it 5-10 times for it to start. it is very random becuse it can happen within 2 minutes of driving or 2 hours. the most ive had it happen to me is after driving for about 20 minutes, and i stop for gas, start it back up and basically just pull out of the gas station and the thing will shut off again. ive tryed another ignition coil but this did not fix it. anyone have any other ideas??
Old Mar 18, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: 99' LX starting and stalling issue
Pull all 4 spark plugs let me know what the ends look like. If you have never done so do a complete tune up, new plugs, cap, rotor, fuel filter, air filter, plugs, clean throttlebody with some throttlebody cleaner and clean the idle air control valve, download the manual in my sig as it will be most helpful with pics and info.
Old Mar 19, 2011
lohnes68's Avatar
ill pull the plugs tmr and let you know what they look like. ive never checked them because i havent been driving the car for too long.
Old Mar 20, 2011
lohnes68's Avatar
so i pulled the plugs and all 4 were fairly white. not so much right on the tip where the v-groove is, but all around them was white. i dont know how old they are or anything....also, i think i have discovered that the car will not stall or give me problems starting if i keep the lights turned off! would this mean a deffinate bad ignition switch?
Old Mar 21, 2011
Newfiedan's Avatar
your car is burning lean, meaning its either a plugged fuel filter, plugged injectors, or a faulty fuel pump usually. There can also be a fault for the 02 sensor reading the primary one which can cause this issue.
Old Jan 28, 2012
jimmyfd's Avatar
jimmyfd is an unknown quantity at this point
Lohness...I have the EXACT same problem and have been unable to solve. How did you fix you problem? THANKS! Jim
jbradley4809
Apr 7, 2017 04:23 AM
crowtoo
May 11, 2015 06:50 PM
McD
Apr 29, 2015 03:50 PM
McD
Apr 16, 2015 10:46 AM
black2k1vtec
Dec 6, 2001 09:49 PM
