"That doesn't sound good!!!"
Old Mar 17, 2011
bmboll's Avatar
bmboll is an unknown quantity at this point
I have a 97 LX with 140000 mi on it. Recently when I come to a stop sign/light the engine starts konking out. It sounds like an old car that keeps running after you turn the engine off. I guess you could call it a "ka-chunk, ka-chunk..." sound. The engine is definitely struggling to keep running, but it does. This only happens with the AC on and it stops once you turn the AC off. Also if you give it a little gas it starts running fine again. The problem is intermittent. I drove it around today with the AC on and it ran like a dream. It seems like once it starts it doesn't go away until the next day.
I took the AC belt off this weekend and the idler pulley and the compressor pulley/clutch plate seem to spin smoothly.
Any suggestions
Thanks
Brian
Old Mar 17, 2011
Re: "That doesn't sound good!!!"
clean out all the intake related parts and sensors.
Old Mar 18, 2011
bmboll's Avatar
Sounds like good advise. I'll check it out
Old Apr 18, 2011
bmboll's Avatar
I know this is a little old but I didn't want to say I figured out what was wrong until I knew for sure
This problem was either low coolant in the radiator or a broken radiator cap (or both). I guess air in the coolant system can cause problems with the idle. It was a nice change to have an easy fix.
autowill
May 15, 2015 11:36 AM
mrohitredd
18
May 14, 2015 07:35 PM
superstanko
Apr 28, 2015 04:38 AM
EC3
Apr 22, 2015 07:55 PM
