cooling problem
cooling problem
recently bought a 1996 civic cx in alberta, being winter the heat has been on high(red) setting since i bought it. however the weather has warmed up and i noticed when i turn the switch to cool(blue) the heat gauge starts to climb. would this be a thremostat problem? or does anyone else have any insight into this problem? thanks in advance.
Re: cooling problem
more than likely thermostat isnt opening as much as it should. also check the fans see if both are working (you can turn them on anytime by switching the a/c on). when the heater is on, it acts as a mini radiator to cool the engine since coolant is running thru the heater core with air blowing over it in the dash for heat.
Re: cooling problem
how high are we talking, above half? And yeah basically what was said by gearbox, the thermostat can be stuck closed, if it goes over halfways I would be looking at this as a suspect. On the bright side its easy to change.
Re: cooling problem
yea very easy to change, thats what i thought, it goes about half way or more, not like totally over heating the fan works i can hear it kick in but the car doesnt have a/c but i will change the thremostat and let u guys know if ur interested in the outcome!
Re: cooling problem
yeah its always nice to hear back on wheter or not you got the problem fixed. I go out to calgary from time to time so if I am in the area and you are stuck with a problem maybe I can help you out.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
brian257
Jun 4, 2015 08:17 PM
dinsum
May 28, 2015 09:30 PM
